DRAW
Create and Modify Views
The 3D View
: Create and Modify Section Planes
From the 3D view, the user can create, manipulate and manage section planes.
To manage section planes, on the
Format 3D
tab, in the
Display
group, click
Section
Planes
to display the
Section Planes
window.
The
Section Planes
window allows planes to be created and amended.
New Stepped Plane
Click to create a new section plane in the 3D view. The section plane is effectively a stepped plane with just two points defined.
Indicate Section Plane Clipping
Indicates section plane clipping is off.
Show Clipping List
Indicates section plane clipping is on. If used where the section is visible in the 3D view, the display indicates the side of the section to be removed.
Show Clipping List
Displays the clipping list for the section planes. Each section plane can have a selective clipping list. The display contents of each list can be colour specific.
Click to display the
Drawlist Management
window. Refer to
Define View Contents
for further information.
Add to Clipping List
Click to add the currently selected element to the clipping list.
Remove from Clipping List
Click to remove the currently selected element from the clipping list.
Section Planes
Displays the name of the view and the identity and properties of each plane.
