Select Element to navigate to the first element in the currently selected hierarchy. The element is selected in the Reference List Members.
Select Member to navigate to the first member of the currently selected element. The element is selected in the Reference List Members.
Select Element to navigate to the last element in the currently selected hierarchy. The element is selected in the Reference List Members.
Select Member to navigate to the last member of the currently selected element. The element is selected in the Reference List Members.
Allows the user to create a drawlist. Refer to Create Drawlist for further information.
Click to display the Create Drawlist window. Refer to Create Drawlist for further information. The user can name the file and click OK to display the Copy Drawlist window.
The Copy Drawlist window allows the user to create a copy of the selected drawlist.
Click OK to create a copy of the drawlist or Cancel to discard any changes and close the Copy Drawlist window. The user is returned to the Drawlist Management window.
Select Design Members from the drop-down list to pick design elements explicitly. The design member elements display in the Reference List Members.
Select Drawlists from the drop-down list to identify design elements from other drawlists. The drawlists display in the Reference List Members.
Allows the user to create and modify lists. Refer to Lists/Collections for further information.
Click to update the Drawlist Management window settings.
All significant elements positioned partially or fully within the current limits box are added to the drawlist. If no limits box is currently defined the Drawlist Limits window displays. Refer to Drawlist Limits for further information.
Allows the user to set the drawlist limits. Refer to Drawlist Limits for further information.
Select As Displayed from the drop-down list to use the drawlist that has produced the current display
Select Use Drawings from the drop-down list to use a drawlist as set at DRWG level. If this is unset, then the option is set to Reference Unset.
Select Use Sheets from the drop-down list to use a drawlist as set at SHEE level. If this is unset, then the option is set to Reference Unset.
Click to display the Drawlist Management window. Refer to Define View Contents for further information.
