Select Metric from the drop-down list to scale the view using metric values. For example, 1/1.
Select Architectural from the drop-down list to scale the drawing using architectural values. For example, 1 1/2" = 1' -0".
Select Engineering from the drop-down list to scale the drawing using engineering values. For example, 1" = 10' -0".
Allows the user to identify corner points for the view frame. Refer to Define View Frame with Cursor for further information.
Allows the user to set the frame size by specifying a ratio or coordinates. Refer to Explicit Frame Size for further information.
The user is prompted to Select element.
Allows the user to offset the design graphics. Refer to Design Graphics Offset for further information.
The Width XR field is automatically updated based on information entered in the From XR and To XR fields. Modifying the Width XR field alters the From XR and To XR fields.
The Height YR field is automatically updated based on information entered in the From YR and To YR fields. Modifying the Height YR field alters the From YR and To YR fields.
Input a dimensional value in the field to specify the width between the From X and To X coordinates.
The Width X field is automatically updated based on information entered in the From X and To X fields. Modifying the Width X field alters the From X and To X fields.
Input a dimensional value in the field to specify the width between the From Y and To Y coordinates.
The Height Y field is automatically updated based on information entered in the From Y and To Y fields. Modifying the Height X field alters the From Y and To Y fields.
