2D drawing sheets can be populated using the 3D view of the 3D model within DRAW. Refer to The 3D View for further information.
Allows the user to define the frame position using a cursor pick in the view. Refer to Define View Frame with Cursor for further information.
Allows the user to position the frame explicitly on the drawing canvas. Refer to Explicit Frame Position for further information.
The user is prompted to Select element
The user is prompted to Select P-point
The user is prompted to Select P-Line end point.
The user is prompted to Select P-Line point.
Select from the drop-down menu to define a view limit from a point on the drawing, using a cursor pick in the view. Refer to Define View Frame with Cursor for further information.
The user is prompted to Specify position
Select from the drop-down menu to define the view limit to a point on the drawing, using a cursor pick in the view.Refer to Define View Frame with Cursor for further information.
Allows the user to apply a different drawlist to the view. Refer to Define View Contents for further information.
Select Universal Hidden Line from the drop-down list to create a Universal Hidden Line view.
Select Global Hidden Line from the drop-down list to create a Global Hidden Line view.
Select Local Hidden Line from the drop-down list to create a Local Hidden Line view.
Select Modelled Wireline from the drop-down list to create a Modelled Wireline view.
Select Wireline Hidden Line View from the drop-down list to create Wireline Hidden Line View.
Select Wireline from the drop-down list to create a Wireline view.
Select Standard from the drop-down list to display all components in the view.
Select Omit Fractional Pipe Components from the drop-down list to remove any piping components that are partly displayed in the view.
Allows the user to define the direction of the view from an element or design point. Refer to Direction for further information.
Allows the user to define attributes for the view. Refer to Limits-Defined View Attributes for further information.
Input dimensional values in the From direction fields to define the limits of the view explicitly.
The direction can be defined in East, West, North, South, Up and Down directions using the drop-down lists.
Input dimensional values in the To direction fields to define the limits of the view explicitly.
Select Metric from the drop-down list to scale the view using metric vales. For example, 1/1.
Select Architectural from the drop-down list to scale the drawing using architectural values. For example, 1 1/2" = 1' -0".
Select Engineering from the drop-down list to scale the drawing using engineering values. For example, 1" = 10' -0".
Input a value in the field to modify the view direction. For example, input N to define a North direction.
The user is prompted to Identify Element
The user is prompted to Identify Design Point
The user is prompted to Identify Pline
Input an angular value in the field to define the perspective angle. A value of 0 indicates a parallel view.
Alternatively, click Pick to display the Pick a colour window. The functionality of the Pick a colour window is explained, refer to Colour for further information.
Alternatively, click Select to display the User-defined linear styles window. Refer to User-Defined Linear Styles for further information.
