Press the down arrow key and select Flat to create a Flat Vsec View. Refer to Create Flat Vsec View for further information.
Press the down arrow key and select clOse to return to the Specify cutting plane position or prompt. The user can click appropriate points of the view to create a closed shaded area.
Press the down arrow key and select Open to resume selection of the shaded area by moving the cursor across the view.
Press the down arrow key and select Perpendicular to create a Perpendicular Vsec view. Refer to Create Perpendicular Vsec View for further information.
Press the down arrow key and select Previous to identify a different location for the cutting plane position.
Press the down arrow key and select Side to invert an area of the shaded view.
Press the down arrow key and select View to create a Vsec view. Refer to Create Vsec View for further information.
Press the down arrow key and select Stepped to create a stepped section view. Refer to Create Stepped Section View for further information.
Press the down arrow key and select Angle to specify an angle to define the area to be removed from the view.
Press the down arrow key and select vErtical to define a vertical area to be removed from the view.
Press the down arrow key and select Horizontal to define a horizontal area to be removed from the view.
Press the down arrow key and select Perpendicular to create a Perpendicular Vsec view. Refer to Create Perpendicular Vsec View view for further information.
Press the down arrow key and select Previous to undo the last point specified.
Press the down arrow key and select clOse to create a closed shaded area
