DRAW User Guide
Create and Modify Views : Create Views
If a Sheet has been created from a template, the Sheet normally contains at least one View, depending on how the template has been set up by the administrator. An existing View can be modified using the Format 2D tab (refer to Format 2D View for further information), Further Views can be created on a Sheet using the options on that tab, or on the Home tab in the View group. The user must be at Sheet level or below before a View can be created.
