Press the down arrow key and select Stepped to create a stepped section view. Refer to Create Stepped Section View for further information.
Press the down arrow key and select Flat to create a flat section view. Refer to Create Flat Section View for further information.
Press the down arrow key and select clOse to return to the Specify cutting plane position or prompt. The user can click appropriate points of the view to create a closed shaded area.
Press the down arrow key and select Open to resume selection of the shaded area by moving the cursor across the view.
Press the down arrow key and select Previous to return to the Specify cutting plane position <or flat> prompt.
Press the down arrow key and select Side to invert an area of the shaded view.
