Input values in the dimension fields and press Enter or click to identify the first corner of the view.
Input values in the dimension fields and press Enter or click to identify the opposite corner of the view.
Input F at the prompt and press
Enter to end the command. The view is created and displays in 3D view mode.
Throughout the view creation process the user can press ESC to cancel the command. Additional functionality is also available.
Add elements to the view as required. Refer to Add and Remove Model Items to/from the 3D View for further information. The Format 3D tab can also be used to further modify the view. Refer to
Format 3D Tab for further information.
Press Enter when the view is complete.
Input values in the dimension fields and press Enter or click to identify the centre of the view.
Input a dimensional value in the field and press Enter or move the cursor left or right to define the width of the view. Click to confirm the required width.
Input a dimensional value in the field and press Enter or move the cursor up or down to define the height of the view. Click to confirm the required height. The view is created.
