DRAW User Guide
Create Drawing Sheets and Support Elements : Modify Department Attributes : User-Defined Linear Styles
To select a user-defined linear style for the department, on the Department Attributes window, click Select to display the User-defined linear styles window.
The User-defined linear styles window allows the user to select a user-defined line style from a list of available Style Tables and a list of available Styles.
The left-hand part of the User-defined linear styles window displays a list of available Style Tables. Select a row to change the display of the List of available Styles.
The right-hand part of the User-defined linear styles window displays a list of available styles. Select a row to be used as the line style.
Click Select to apply the user-defined line style or Cancel to discard any changes and close the User-defined linear styles window. The user is returned to the Department Attributes window.
