The Pick a colour window allows the user to define the text, line or hatch pattern colour.
Select a colour from the palette, the colour is indicated at the bottom of the Pick a colour window.
Click More to display a large colour palette. When the large colour palette displays, the user can click Less to display a small colour palette.
Close the window to apply the selected colour or click Cancel to discard any changes and close the Pick a colour window. The user is returned to the Department Attributes window.
Alternatively, click Select to display the User-defined linear styles window. Refer to User-Defined Linear Styles for further information. If a user-defined linear style is selected, the check box and field are populated, by default.
Alternatively, click Select to display the User-defined fill styles window. The functionality of the User-defined fill styles window is identical to the User-defined linear styles window. Refer to User-Defined Linear Styles for further information. If a user-defined fill style is selected, the check box and field are populated, by default.
