To preview the spooling, on the Tasks part of the
Isometric Production window, select a Design element in the
Search Results table, click
Preview Spooling.
The Isometric Splitting tab displays, with a graphical representation of the CE in the 3D view. All of the manipulation functionality common to all design modules is available. Refer to
Model Editor for further information.
The Split Control functionality, on the Isometric Splitting window, is dependant on the default
Splitting setting. If splitting is
By Volume, the
Split drop-down list allows the user to change the complexity of spool splitting.
The user can change the split positions of the spool as a percentage of the original split points. For example, select 50% from the
Split drop-down list to introduce split points at approximately half the distance of each original split position.
If splitting is By Split Point the user is not able to modify the spool splitting as it is controlled by data held in the 3D model. Select another entry in the Search Results Table, the 3D view is updated for the new element, by default.
