DRAW User Guide
Add Annotation : Automatic Tagging : Tagging Template Leader Line
To define the tagging template leader line attributes, on the Automatic Tagging window, select Local from the Template Type drop-down list, select Leader Line from the Attributes drop-down list to display the Tagging Template leader window.
Alternatively, click Pick to display the Pick a colour window. The functionality of the Pick a colour window is explained, refer to Colour for further information.
Alternatively, click Select to display the User-defined styles window. Refer to User-Defined Linear Styles for further information.
Select On from the drop-down list to turn the label leader line visibility on.
Select Off from the drop-down list to turn the label leader line visibility off.
Click Apply to modify the leader line attributes or Cancel to discard any changes and close the Tagging template leader window.
