DRAW User Guide
Add Annotation : Automatic Tagging : Label Frame Attributes
To define the label frame attributes, on the Automatic Tagging window, select Local from the Template Type drop-down list, select Frame from the Attributes drop-down list to display the Frame Attributes window.
Select On from the drop-down list to display the frame.
Select Off from the drop-down list to hide the frame.
Alternatively, click Pick to display the Pick a colour window. The functionality of the Pick a colour window is explained, refer to Colour for further information.
Alternatively, click Select to display the User-defined styles window. Refer to User-Defined Linear Styles for further information.
When a style is selected, it populates the Style field and the check box is selected.
Click Apply to define the label frame attributes or Reset to revert to the values applied when the Label Frame Attributes window was opened.
Click Cancel to discard any changes and close the Label Frame Attributes window.
