DRAW
Add Annotation
Label Objects
: Add Copy of Label
Add Copy of Label
To add a copy of a label, on the
Annotate
tab, in the
Annotate
group, click
Label
to display the
Select
window:
The
Select
window allows the user to select the required label template (GLAB) from the GLAB template folder.
Select the required template and click
Select
The user is prompted to
Specify attachment point or <Template>
Input
S
at the prompt and press
Enter
The user is then prompted to
Select label element
Click to identify the label to copy.
Click the label leader line attachment point.
Select design element
Click to identify the design element to be labelled. A copy of the label is added to the drawing
The process can be repeated, allowing the user to add multiple labels.
Press
ESC
to end the command.
Throughout the label copy process the user can press
ESC
to cancel the command. Additional functionality is also available.
Sameas
Press the down arrow key and select
Template
to select a different label template.
Template
Sameas
to specify a different label to copy.
