DRAW User Guide
Add Annotation : Label Objects
To add label design elements, on the Annotate tab, in the Annotate group, click Label to display the Select window.
The Select window allows the user to select the required label template (GLAB) from the GLAB template folder.
The user is prompted to Specify attachment point or <Template>
Input values in the dimension fields and press Enter or click to identify the label leader line attachment point.
The user is then prompted to Select design element
The user is then prompted to Specify connection point or <Template>
Input values in the dimension fields and press Enter or click to identify the position of the label text.
When the user has input and formatted the text using the Text Editor window and clicked OK, the label is added to the drawing.
Press ESC to end the command.
Throughout the label creation process the user can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Sameas to add a copy of a label. Refer to Add Copy of Label for further information.
Press the down arrow key and select Template to select a different label template.
