Schematic 3D Integrator User Guide
Integrator Functions in Detail : How Integrator Compares Schematic and 3D Data : Comparing in Line List Mode
From the Integrator bar menu, select Settings > Comparison Settings then check the option to Compare Pipelines and Pipes without their member hierarchies. This will ensure Integrator compares only the top level items (without this setting Integrator will report all the 3D piping components as unmatched).
From the Integrator bar menu, select Settings > Line List Options to display the Line List Configuration dialogue. Create an SCPLIN rule for LLFROM, setting the Prefix to take its value from :FROM, with a comma separator, and the flag to include SCBRANCH values set to false.
Figure 5:27.
Create a similar SCPLIN rule for LLTO taking its value from :TO.
Figure 5:28.
Create a Component Rule for LLFROM and LLTO with end condition set to Valid HREF/TREF. Add NOZZLE to the list of item types, set the expression to NAME and select EndComponent for the expression object.
From the Integrator bar menu, select Display > Project Configuration Explorer (refer to How to Configure Build Rules for more information). Create the two SCPLIN rules to match LNTP and FUNC as key attributes.
