Schematic 3D Integrator User Guide
Integrator Functions in Detail : How Integrator Compares Schematic and 3D Data
In the Main Table or Diagram Viewer select the objects you want to compare, then select Context Menu > Compare. You can also select Compare in the Integrator Main Bar Menu or Compare Diagram in the background menu of the Diagram Viewer. These options are described in the Main Table Context Menu in Integrator Controls.
You can also initiate Compare from the Command Line. This process is described in How to use Integrator from the Command Line.
