Schematic 3D Integrator User Guide
Integrator Controls : Subtype Table Options : Column Setup
Select Subtype Table Menu > Column Setup. The procedure for changing the subtype Column Setup is the same as changing the Main Table Column Setup. Refer to Column Setup.
