.NET Customisation
.NET Customisation
Introduction
Sample Code
: ExamplesAddin
ExamplesAddin
A zip file (Samples.zip) containing the samples can be found in the installation directory. .NET API Examples can be found in the ExamplesAddin project below the Samples directory. This is a C# addin which adds a ComboBoxTool on a Toolbar to the main menu. Each entry in the list runs a particular example. This can be loaded by adding the ExamplesAddin to the applications addin config file. Since these examples create and claim Design elements they need to be run in a Design multi-write database. There is an example config file in the ExamplesAddin directory.
