.NET Customisation
.NET Customisation
Introduction
: Sample Code
Sample Code
A zip file (Samples.zip) containing the samples can be found in the installation directory. For the projects assembly references to be valid the zip file should be unzipped into the installation directory. It will create a Samples directory containing the sub-directories described below. If they are moved elsewhere then the references to assemblies in the installation directory will need to be updated.
Samples are provided which are compatible with Visual Studio 2005, and Visual Studio 2005 Express.
