Clash Manager
Model Management Wizard
Project Maintenance
Clash Manager Options
: Import Clash Manager Data and Export Clash Manager Data
These options are provided to help administrators manage customisation and project data. Customised setup can be copied from one project to another using an Export from the original project as Import to a new project. Export/Import also provides a basic backup facility for administrators with limited Oracle Administration experience. Experienced Oracle Administrators will probably prefer to use the more flexible, but more complex, backup facilities provided as an integral part of Oracle.
After the Import/Export option has been selected, the administrator will be asked to enter the Oracle Username and Password for the relevant project and specify whether Import or Export is required.
The Export process creates a file of exported information. The Model Management Wizard suggests what filename should be used, but the administrator is able to override the name and location. By default only customisation information is exported, but a full data export can be selected.
The Import process reads a file of exported information. The administrator is asked to Browse and select a file created by the Model Management Wizard’s Clash Manager Export option. The administrator is able to select which parts of the customisation from the Export file are to be imported into the receiving project. If any conflicts between the information to be imported and existing configuration and customisation in the receiving project are detected the administrator will be asked to resolve these.
