Identify the section which is to have a snipe added by entering a name in the Modifying Section text box or clicking
CE to modify the current element, if it is an angle section.
Make the required selection using the Select Sniped End radio button. If the Identify by Cursor icon
is activated, then the sniped end of the angle section can be picked directly from the 3D graphical view. If the
Auto function is enabled, the snipe is created immediately after picking, to speed up the process.
Enter values into the Snipe Length and
Snipe Height fields. If the
Lock/Unlock icon
is activated, the two values are locked together, and changing one changes the other.
Click Create to confirm creation of the snipe.
Click Delete to remove an existing snipe.
