Multi-Discipline Supports
Add Snipes to Steelwork Members
MDS provides the ability to create and modify snipes on support structural members. A snipe is where a support structural member is cut at an angle, such that a corner is removed.
This feature currently only works with angular sections, i.e. steelwork profiles of type SCTN and gtype ANG. Two cases are catered for:
Snipe on end of leg attached to stiffener
Snipe on free end of section.
Snipe on End of Leg Attached to Stiffener
When the section is attached to a stiffener the following calculations are used, where
SL =
Snipe length on the leg of the framework
FL =
Length of leg section
M1 =
Control gap for back-to-back (default = 10 mm)
M2 =
Length in the opposite direction of M1 on flange of stiffener
M3 =
Distance between flange top outside edge of stiffener and leg point connected with the flange top of stiffener (default = 25 mm)
When L > M1 + FL + M2 and M2 >= 25mm, Snip is not provided on support leg as below.
When L > M1 + FL + M2 and M2 < 25mm
Snip is to be provided on support leg as below
When L =< M1 + FL and M2 (=M1 + FL - L) =< 0 (zero) mm
Figure 3:1.
Snipe on Free End of Section
When the section is not attached to a stiffener the following calculation is used:
