Multi-Discipline Supports User Guide
Using the MDS Application : Repeat a Support : Repeat Support Frame
1.
Select Create > Repeat MDS Framework Support from the main menu.
4.
Type a name for the new frame, or click MDS Autoname, then click OK. Click on Cancel to use the default name.
To exit the procedure, press the Esc key on the keyboard.
