Multi-Discipline Supports
Using the MDS Application
: Create and Manipulate Connections to External Steelwork
After the structural steelwork has been created, it may be necessary to connect it to external steelwork.
To add a connection to external steelwork:
Select the Create Connections icon
. This creates a connection only if the application knows the identity of the steelwork to connect to.
If the user used the
Create by Cursor
or
Create by Clearance
methods the connection to the external steelwork is made automatically.
It is essential that the user has write access to create SNOD/SJOI elements on the necessary external steelwork.
The SNOD is represented in the graphical view. The MDS application defaults control the level at which joists can be made to the external steelwork.
Refer to the
MDS Administrator Guide
for more details.
1.
Select the Modify Connection icon
. The user is presented with a window that displays all the available joints.
2.
Select the joint for the joints connected to the external steelwork.
If the user has identified the external steelwork to connect to with either Create by Cursor or Create by Clearance, it is possible that the application will connect to the wrong Pline. This can happen in the case of the SCTN having floating Plines (X) ((a) in
Figure 2:11.: Forced connection to SCTN with floating Plines
Figure 2:11.
The user can force-connect the joint to a specific Pline ((b) in
) by selecting the Force Connect icon
. the user is prompted to identify the required Pline using the cursor.
To delete a connection:
1.
Identify the connection with the cursor.
2.
Select the Delete Connections icon.
