Multi-Discipline Supports User Guide
Using the MDS Application : Create Support
To create a support, on the Supports tab, in the Create group, click Framework to display the Multi Discipline Frameworks window.
Enter a name in the Name text box or click Autoname. After entering a name, OK becomes active.
Clicking View displays the engineering drawing corresponding to the selected support.
Right-clicking on AutoName and clicking Select Naming File,
displays the MDS AutoNaming File window which allows the user to select a different AutoNaming file for the session or a different AutoNaming file set for the zone. Refer to MDS - Auto Naming for further information.
2.
Click OK. The type is selected and the window closes. Refer to the MDS Administrator Guide for further information.
1.
Click OK on the Multi Discipline Frameworks window. The XFT09 - MDS Framework window is displayed.
See Modify a Support for a descriptive overview of the icon functions.
To support cable rack or HVAC using the datum atta Create HVAC… or Create Rack… from the Create pull-down menu, or the equivalent icon in the MDS toolbar must be used. Where cable rack was created by the Cabling System application (and so is made up of cable tray (CTRAY) elements), a cable tray support element (CTSUPP) is automatically used in place of a support attachment element (ATTA).
To create the datum atta select Create datum support atta at the top of the window. The user is presented with the cursor so that the user can identify a pipe. When the user has done this, the Ancillary Selection window containing a filtered list of all the available ancillaries at the selected pipe bore, is displayed (Figure 2:2.: Ancillary Selection window). These may be restricted for each framework type. For more information refer to the MDS Administrator Guide.
4.
Select the ancillary XAT16 (Bolt on Shoe) from the window. Click OK. The application now creates the pipe shoe on the selected pipe and positions it at the previous component or branch start, with a graphical tag of Datum for easy recognition. Create datum support atta is deactivated.
1.
Distance , with a distance value placed in the text field next to it,
2.
any of the Through options. These include; Through ID Cursor, Through Back Mark, etc.
The example in Figure 2:3.: Design screen 1 shows two pipes, HVAC and cable rack elements added to the support.
Figure 2:3.
8.
Select a template available from the list presented on the window (Figure 2:4.: Set Steelwork Size window). The template list shows all available templates. For this exercise, choose the second option, 80x80x10 Angle, Internally Welded.
9.
Click Cancel to accept the selection and return to the XFT09 window (Figure 2:1.: XFT09 - MDS framework window).
