Multi-Discipline Supports
Administrator Guide
MDS Admin Data Form
Options (2) Tab
: Weight Unit (MDSWEIUNIT)
Default value
Session/default catalogue modifiable
Description
1
Default catalogue
This value is a conversion factor that allows output of weights in units other than kg.
All catalogue weights are stored in the database in kg. This setting is used in weight calculations and enables output in lbs, or any other desired units. The options are:
1 (kg) =
output in kg
2.2046 (lbs) =
output in lbs
Other =
Any other weight units. Enter the appropriate conversion factor in the numeric entry box.
