Multi-Discipline Supports Administrator Guide
MDS Admin Data Form
The MDS Admin Data form is the main control form for the MDS application. It allows the administrator to control some of the design limits within which supports can be created. The form also allows the administrator to set the criteria that MDS uses to locate support zones etc.
The MDS Admin Data form modifies values in /MDS/OPTION/DEFAULTS, which are the defaults that are set for the MDS Application Defaults form in MDS design.
Changes made are only applied to the database when the Apply button is pressed. To keep the changes ‘Save Work’ operation needs to be performed.
The Dismiss button removes the form. If changes have been made, but not applied, a window is displayed asking if the changes are to be applied before exiting.
