If a Database View is created that has the Element Types (ELEL) attribute set to UDA then the node at the top of the Data Sources tree represents the collection of UDA elements.
If a SRCELEMENT node is created below this with its Expression set to OWNER, then the Source Element represents UGROs, the OWNER elements of the selected UDAs
Since SRCELEMENTs are allowed to contain SRCELEMENTs navigation steps are incremental. Another node with its Expression set to OWNER represents UWRLs, the OWNERs of the OWNERs of the selected UDAs.
The NAME attribute is present on UDAs, UGRO and UWRLs. Creating an Attribute column for the NAME attribute and selecting different Data Sources changes the element the NAME attribute is being displayed/edited on.
Creates a new Data Source in the current context
Deletes the selected Data Source.
Sets the Current Element (CE) to the definition element for the Data Source, this expands the Dictionary Explorer if displayed
Places the selected item on the Database Views Editor clip board ready for a Paste operation. Pasting the item moves it.
Creates a copy of the selected item on the Database Views Editor clip board.
Pastes the item on the Database Views Editor clip board into the current context
The expression used to derive a value for the parameter, if unset the user is prompted. If the element if being created for a SRCELE Data Source then the expression is executed on the element defined by the parent Data Source otherwise it's executed on the Current Element (CE).
