If a Database View is selected from the
Views pane in the
Database Views Editor, the
View Detail Pane is displayed. The
Database View can be modified with the following limitations:
The View Detail pane of the
Database Views Editor window is displayed with four tabs populated with following:
Supports modification of the primary attributes of a Database View to define the display name and the elements that the
Database View rows are based on.
The columns displayed to the user for each Data Source, these can be attribute values or expressions evaluated on the selected
Data Source.
A grid showing column data defined by the Database View. The grid only shows data that the current user has access to. By default data access is restricted in LEXICON so this will appear as an empty grid for most element types.
