HVAC
Administrator Guide
Defaults
: Units
Units
The defaults used must correspond to the units being used or else the default value of 500 may be interpreted as 500inches rather than the intended mm.
There is a concept of application units; where, variable !!CDHVACUNITS is set to 'MM' or 'INCH' in the defaults file.
The user can select different defaults from Settings>Ductwork Defaults…
