HVAC
Administrator Guide
Defaults
Defaults
All the standard components have default values that can be changed by the user. For example a Taper piece may have a default length of 500mm when in metric and 20inches when in imperial. The defaults are the values that appear on the creation form as the initial value. The Administrator can change these to 600mm or 24inches by creating or editing data elements as follows:
The standard HVAC defaults are stored as
To make user defaults :
new cata /USERHVACDFLTS copy /CADCHVACDFLTS rename $ /CADCHVACDFLTS /USERHVACDFLTS
Then modify the data values, for example:
/USERHVACMDFLTS-RMELBOW-ATHR dprop (150)
Etc.
There is then a file %AVEVA_DESIGN_DFLTS%/hvacadv/userhvacmdflts that sets /USERHVACMDFLTS as the default.
To force this to always be the default, the administrator can edit the file %PMLUI%/des/ hvacadv/init.
