If the project has been configured with User Defined Element Types based on electrical component (ELCONN) element type, they display in the User Defined Type drop-down list. When the electrical component element is created, it is created as the User Defined Type selected from this list. Selecting a User Defined Element Type may change the content of the Selection Table if the table has been configured to filter on element type.
The user can group the search results of the Create Electrical Component window. Select a
Column Header, for example
RPM, and drag and drop the selection into the
Drag a column header here to group by that column field.
A component can be selected by clicking on a row in the table. Click Properties to display the
Modify Properties window, the user can define parameterised data relevant to the selected electrical component.
Click Plotfile to display a diagram of the component, if one has been provided, with the component definition. The diagram can also form part of the
Modify Properties window.
The Component Position part of the
Create Electrical Equipment window displays at the bottom of the window. The functionality available from the
Create Electrical Equipment window is identical to that available in the
Modify Primitive window.
