Equipment User Guide
Equipment : Create : Nozzle
On the Equipment tab, in the Create group, click Nozzle to display the Nozzle Creation window.
The Create Nozzle window allows the user to define the nozzle specification.
Displays the Primitives window, indicating the Parameters fields along the axis.
The Bore specifies the nominal bore of the nozzle. Select a bore from the drop-down list of available bore sizes.
Input a description in the Description field.
Click Create to display the Nozzle in the 3D view or close the Create Nozzle window to discard any inputs.The Modify Nozzle window displays by default.
