The Create Primitive window displays the parameters fields for a Box. Refer to Box Parameters for further information.
The Create Primitive window displays the parameters fields for a Cylinder. Refer to Cylinder Parameters for further information.
The Create Primitive window displays the parameters fields for a Cone. Refer to Cone Parameters for further information.
The Create Primitive window displays the parameters fields for a Snout. Refer to Snout Parameters for further information.
The Create Primitive window displays the parameters fields for a Pyramid. Refer to Pyramid Parameters for further information.
The Create Primitive window displays the parameters fields for a Circular Torus. Refer to Circular Torus Parameters for further information.
The Create Primitive window displays the parameters fields for a Rectangular Torus. Refer to Rectangular Torus Parameters for further information.
The Create Primitive window displays the parameters fields for a Dish. Refer to Dish Parameters for further information.
The Create Primitive window displays the parameters fields for a Sloped Cylinder. Refer to Sloped Cylinder Parameters for further information.
Displays the Create Negative Primitives window. Refer to Create Negative Primitive for further information.
Displays the Primitives window, indicating the Parameters fields along the axis.
The user is prompted to Define vertex (Distance[0]) Snap :
The Positioning Control window displays by default. Refer to Positioning Control for further information.
Displays the Define vertex window. Refer to Define Vertex Offset from Previous for further information.
Displays the Radius window. Refer to Construct a Fillet Arc with Specified Radius between two Tangential Lines for further information.
The user is prompted to Extrusion arc (three points) first point (Distance[0]) Snap :
then Extrusion arc (three points) second point (Distance[0]) Snap :
The user is prompted to Extrusion arc (through 2 points) start point (Distance[0]) Snap :
then Extrusion arc (through 2 points) end point (Distance[0]) Snap :
From the drop down menu, click to identify the direction of the East/West axis. The user can then input an explicit position value in the Position field.
From the drop down menu, click to identify the direction of the North/South axis. The user can then input an explicit position value in the Position field.
From the drop down menu, click to identify the direction of the Up/Down axis. The user can then input an explicit position value in the Position field.
Click to discard any inputs and close the Loop Vertex Editor window.
When Confirm is selected the user must click Modify at the bottom of the window to implement each modification. When Confirm is not selected each modification is implemented immediately.
When Confirm is selected the user must confirm each deletion in order to complete the command. When Confirm is not selected deletions are implemented immediately.
When Tag edges is selected each edge is tagged with the number of the vertex at its start.
When Display Axes is selected the axes of the primitive are displayed at the first vertex in the 3D view.
When Free rotate is selected groups of vertices can be orientated by default when moved from one edge to another.
The user is prompted to Pick points, <escape> to select :
The user is prompted to Pick near edge :
The user is prompted to Pick screen position :
The user is prompted to Create new vertex(Distance[0]) Snap :
In vertex mode, the user is prompted to Pick screen position :
In edge mode, the user is prompted to Pick near edge :
The Vertex/Edge Counter displays the currently selected vertex/edge in the 3D view. The user can navigate to a specific vertex or edge by inputting the vertex/edge number in the text field. Alternatively, select the up/down arrows to step through the list.
Moves each edge of the group outwards by the distance specified in the Expand/Contract text field normal to its own direction.
moves each edge of the group inwards by the distance specified in the Expand/Contract text field normal to its own direction.
Moves the Start vertex along the edge direction to align it through a picked position using a cursor pick in the 3D view.
The user is prompted to Pick point start is to be projected through :
Alternatively, if a line is selected, the End vertex is moved along the edge direction until it intersects the picked line. These operations can change the edge length.
Moves the End vertex along the edge direction to align it through a picked position using a cursor pick in the 3D view.
The user is prompted to Pick point end is to be projected through :
Alternatively, if a line is selected, the Start vertex is moved along the edge direction until it intersects the picked line. These operations can change the edge length.
The user is prompted to Pick line to be made parallel with :
Rotates the edge anticlockwise, through the rotation angle specified in the Angle text field, about the reference end. The operation maintains the edge length.
Rotates the edge clockwise, through the rotation angle specified in the Angle text field, about the reference end. The operation maintains the edge length.
When Best Fit is selected, the Equipment application attempts to construct the circle which best fits between adjacent arcs or points by default. The circle has twice the minimum radius which just fits between the adjacent arcs.
The Create Negative Primitive window displays the parameters fields for a Box. Refer to Box Parameters for further information.
The Create Negative Primitive window displays the parameters fields for a Cylinder. Refer to Cylinder Parameters for further information.
The Create Negative Primitive window displays the parameters fields for a Cone. Refer to Cone Parameters for further information.
The Create Negative Primitive window displays the parameters fields for a Snout. Refer to Snout Parameters for further information.
The Create Negative Primitive window displays the parameters fields for a Pyramid. Refer to Pyramid Parameters for further information.
The Create Negative Primitive window displays the parameters fields for a Circular Torus. Refer to Circular Torus Parameters for further information.
The Create Negative Primitive window displays the parameters fields for a Rectangular Torus. Refer to Rectangular Torus Parameters for further information.
The Create Negative Primitive window displays the parameters fields for a Dish. Refer to Dish Parameters for further information.
The Create Negative Primitive window displays the parameters fields for a Sloped Cylinder. Refer to Sloped Cylinder Parameters for further information.
Displays the Create Negative Extrusion window. Refer to Create Negative Extrusion for further information.
The user is prompted to Pick Surface to be used as datum :
