Equipment User Guide
Equipment : Create : Sub-Equipment
On the Equipment tab, in the Create group, click Equipment, select Sub-Equipment from the list to display the Create Sub-Equipment window.
From the drop down menu, click to identify the direction of the East/West axis. The user can then input an explicit position value in the Position field.
From the drop down menu, click to identify the direction of the North/South axis. The user can then input an explicit position value in the Position field.
From the drop down menu, click to identify the direction of the Up/Down axis. The user can then input an explicit position value in the Position field.
The wrt text box displays the owning equipment element by default, the user can input an alternative value in the field.
