DRAW Reference Manual
Using the Cursor with DRAW Commands : Snapping 2D Points to a Grid
Cursor commands which request 2D points will be rounded to the nearest point on the SNAP grid (if on). The grid is defined by the SNAP command, for example:
- turn the snap grid on
- turn the snap grid off (the default)
- define a square grid, 10mm in both X and Y directions
- define a rectangular grid
VGRID [sheet identifier] OFF
ERASE AIDS [IN sheet identifier]
ERASE VGRID [IN sheet identifier
Q VGRID sheet_identifier
