DRAW Reference Manual
Using the Cursor with DRAW Commands
ID element_type @
- element_type is any Design, Catalogue or Drawing element (e.g. EQUI, SHEE)
- select and identify valve
- select and identify valve or VTWA
- select and identify nozzle
Refer to Dimensioning, Labelling and 2D Drafting for ID commands relating to Dimensions, Labels and 2D drafting respectively.
Picking an element with the cursor will make the item the current element (i.e. the current position in the database will move to that item). If you select a DESIGN element (e.g. a Cylinder primitive in a vessel) you will move to the DESIGN database; if you select a Drawing element (e.g. the edge of a Sheet) you will move to that element within the DRAW database.
