- Create a VIEW Section element under a Layer
PLRF name
- The reference name of the plane to be used
IDLN name
- An Id list name for the section to operate on. If left undefined will default to the Id list specified by the VIEW.
- The Mode in which the plane will be used to section the view, i.e. which side will be retained or discarded. The default is either STANDARD, which is as the plane is set up, or REVERSE, which switches which side is retained or discarded. For a SPLA or FPLA, this has the same result as using the CHANGE ACTIONS command.
