DRAW Reference Manual
Drawing the Design
Defining VIEW Contents Using Id Lists
: Querying Id Lists
Querying Id Lists
Q
FOR
/design_element_name
At an IDLI, or at a VIEW.
Q IDLN FOR
A series of Design element names may be specified, separated by spaces or commas
These commands will output information on whether the named element is wholly included in the named Id List (i.e. in the Id List and no member elements REMOVEd), partially included in the named Id List (i.e. in the Id List but some member elements REMOVEd), or absent from the named Id List. The Id List name/VIEW name is not required if the current element is the Id List itself or a related VIEW.
Q
IDLN DESC
(at a VIEW) outputs Id List members and limits.
Note that querying the Id List in the usual way will list its ADDE and REME elements; a more comprehensive output can be obtained by:
Q DESCRIPTION
(at IDLI, ADDE or REME elements)
Other querying commands relating to Id Lists are:
Q MAP
Lists status of spatial maps in the current MDB
Q VOLUME
identifie
r
Gives encompassing volume of given element
Q WINDOW
volume
Lists significant elements in the given volume
