Library (LIBY) elements can appear at four positions in the hierarchy (Refer to DRAW Database Hierarchy for further information). They are administrative elements used to group together several types of sub-library. The type of sub-library of interest here is the Drawing List Library (DLLB).
The DLLB is used to group together Id List (IDLI) elements.
When evaluated individually both /LIST2 and /LIST3 must define a set of design elements which are then added to/removed from /LIST1, respectively. In particular if /LIST3 is being used to remove a number of Branches (say) from /LIST1 then it should be defined as:
ADD /BRAN1, /BRAN2, /BRAN3 and NOT as: REM /BRAN1, /BRAN2, /BRAN3 |
