DRAW Reference Manual
Point and Line Construction
: X, Y Filtering
X, Y Filtering
A 2D position may be defined in terms of the X or Y coordinates of other points. For example, rather than an explicit point definition such as:
AT X200 Y200
a constructed point could be defined by:
AT X200 Y OF
point
The above command would define a position whose Y coordinate would be the Y coordinate of
point
, where
point
could include:
The endpoint of a line or an arc
The centre of a circle or an arc
A tangency point
An intersection points
The point on a line or an arc nearest to a given point
The point defined by the perpendicular from a given point
The constructed point could also be defined explicitly or by a cursor hit. For example:
AT X200 Y OF @
Set the Y coordinate to the Y coordinate of the cursor hit
AT X OF @ Y OF @
X coordinate from first cursor hit, Y coordinate from second cursor hit
The process of deriving a coordinate from a coordinate of another point is known as
X
Y filtering
. X and Y filters may be used in any command that requires a 2D position on a Sheet, including edits on various Dimension attributes. For example:
PTOF X OF /VALV1 Y @
DTOF X @ Y250
PLCL X @ Y OF POS E3000 S2000 U0
Y coordinate set to the Y coordinate of 2D projection of given 3D position.
3D positions may also be constructed, but this only applies to 2D drafting primitives that are members of VNOT elements. X, Y filtering can be used with any 2D element which has a position attribute, e.g. VIEWs, Labels, Dimension Points etc.
Examples
1.
NEW STRA
FPT X100 Y100
TPT X OF @ Y OF @
(or
NEW STRA DEF X100 Y100 X OF @ Y OF @
Here a straight line is created with one of its endpoints defined explicitly and the other constructed using cursor hits. Refer to
Figure 19:1.: X, Y Filtering - General 2D Position
for further information.
Figure 19:1.
Here, the ‘to’ point of the line takes its X coordinate from the X coordinate of hit 1 (at 200, 300) and its Y coordinate from the Y coordinate of hit 2 (at 500, 400). The ‘to’ point is therefore (200, 400).
2.
DTOF X @ Y250
With a cursor hit at (400, 900), the above command would move a Dimension text origin to (400, 250).
3.
Here, a projection line clearance X coordinate would be set to the X coordinate of the cursor hit, the Y coordinate being set to the Y coordinate of the 2D projection of the given 3D position.
