DRAW Reference Manual
Point and Line Construction
You can define a position in terms of other positions rather than defining it explicitly using the
point construction
facilities in DRAW. Point construction is available for
Positioning of 2D drafting primitives
Labelling, where a 2D position is required, e.g. positioning of gaps
Dimensioning, where a 2D (or, if appropriate, a 3D) position is required, e.g. positioning of a point through which a dimension line should pass
Positioning of Overlay Sheets
VIEW position attributes, e.g. THPO, FRPO, ONPO, VREG command
SYTM and TXTM positioning.
As well as points, it is also possible to construct lines and arcs.
