DRAW Reference Manual
Point and Line Construction : Introduction
It is also possible to construct a drafting point position, using commands such as:
ORIG MIDP position position
ORIG OFFSET 2D_vector
ORIG position DIST distance
Here, position may be any of:
2D_vector specifies an offset position from the owner origin of the primitive concerned, for example
distance gives a distance and a direction from a point, and may be one of the following in a NOTE or SYTM:
units_value
ANGLE value
HORIZONTAL
VERTICAL
2D_vector
For a VNOT, distance may be expressed as
units_value DESIGN direction
where direction is a 3D, p-point or p-line direction. The distance specified is a Design distance in the current View. The above syntax may also be used in most drafting commands, e.g. FPT, TPT, CPT, DEFINE, DRAG TO, LENGTH, RADIUS etc.
