Figure 17:7.
Changes the XLEN by distance along the X axis of the primitive from the origin. Note that this is not necessarily the Sheet or Note axis. If the origin is at the midpoint of the X axis (i.e.ORIG CENTRE) then XLEN will be twice this distance. If appropriate a Design distance will be used
Changes the YLEN by distance along the Y axis of the primitive from the origin. Note that this is not necessarily the Sheet or Note axis. If the origin is at the midpoint of the Y axis (i.e.ORIG CENTRE) then YLEN will be twice this distance. If appropriate a Design distance will be used
Defines a rectangle where dfnpt1 defines a position (2D, 3D, p-point etc) which is the centre of the rectangle, and dfnpt2 defines the position of a corner.
Defines a square where dfnpt1 defines the centre of the rectangle, and dfnpt2 defines the position of a corner.
SDEFine dfnpt1 dfnpt2
LENGTH value [DESIGN]
ADEG value
STR As positioned at a 3D point cannot be shifted by an X,Y amount, and vice versa.
ALENGTH value
