As a primitive element is created, its position is stored separately, with a
reference to the position being stored as the primitive’s PTRF (or PTFA) attribute. An important feature of this system is that if a series of primitives is created, each primitive’s position reference (or
drafting point) will (initially) be the same, enabling a series of ‘connected’ shapes to be quickly and easily created. For example, the command sequence
would create a series of concentric circles. In a similar way, a series of connected straight lines could be created. (A line may have two position references, one at either end; the start position reference of one line would be set equal to the end position reference of the previous line. Refer to
Creating and Manipulating Drafting Primitives - Common Operations for further information.) A set of primitives connected in this way may be moved as a ‘group’ by using the DRAG command.
