DRAW Reference Manual
Labelling : Creating and Manipulating Labels : Modifying Labels through Graphical Interaction
The Annotation Modification Form will appear, and the selected Label is highlighted with pickable hot spots. These enable the APOF, BPOF, CPOF, XYPS, and ADEG attributes of the Label to be modified interactively.
For this functionality to be available the Annotation Modification form must be loaded. The form contains the point construction Option list button that allows positions to be defined in terms of end-points, intersection points, etc.
Click on OK on the form, to accept the changes you have made.
Cancel allows the command to be aborted with no change to the Label.
Reset causes the position of the current hot-spot to be reset to its database position; Delete causes the current hot-spot to be deleted or set to a default position:
