DRAW Reference Manual
Labelling : Creating and Manipulating Labels
The example Label shown in Figure 12:2.: A Typical Label Element could be created simply by typing the following (starting at LAYE) level:
create new General Label (or NEW SLAB to create a Special Label)
The above two commands are all that is needed to create a Label with the features shown in Figure 12:2.: A Typical Label Element; the text which appears in the Label frame is by default the name of the Design element at the Label attachment point, all other attributes having default settings cascaded down from the owning Layer.
For elements that have p-points or p-lines the attachment point can be varied by setting the NPPT or PKEY attributes to the specified p-point number/p-line name respectively.
Example:
For elements with p-lines the attachment can be further varied by setting the PKDI p-line distance) attribute. Refer to P-line Attributes for further information.
Example:
The Label attachment point can be offset from the DDNM using the APOF (Attachment Point Offset) attribute. This defines an offset position (in VIEW coordinates) measured from the p-point/p-line distance referenced by the Label. The leader line will be attached to this point (although if the clearance attribute (LLCL) is set the leader line will overshoot or stop short of it). This means that the leader line and its terminator can be moved away from the p-point to any desired position. By default APOF will be (0,0) - i.e. no offset. APOF may be set directly, for example:
The Body Text (BTEX) attribute is by default set to the ‘intelligent text’ string #NAME, which translates to the name of the Design element at the attachment point when the Label is created. If the Design element at the attachment point is unnamed, an ‘error-text’ string will appear in the Label frame. This string is customisable and defined by the LAYE’s NTEXT attribute. Refer to Customizing Error Text for further information.
would produce the Label shown in Figure 12:3.: Label Text. Note how the size of the Label frame automatically adjusts to accommodate the specified text.
Figure 12:3.
Note the special hash-code ‘#/’ that generates a new line. Refer to Intelligent Text for further information about DRAWs Intelligent Text System.
Refer to Text Strings for further information.
Label text can be edited through use of the EDTEXT command. For example, if the target string is ‘NOZZLE 2’:
