When a Label is created, its origin (held as the XYPS attribute) is placed at a fixed offset (default x 25mm, y 25mm) from its attachment point. The Label origin (and hence the Label) may be moved by the AT @ command, which resets XYPS to the position specified by the cursor. This command calls up the
Point Construction Option form, which contains the point construction
Option list button which allows positions to be defined in terms of end-points, intersection points, etc.
Note that the coordinates specified with the AT command (whether explicit or from cursor input) are always taken to be absolute coordinates, irrespective of the OSET setting. To avoid any potential confusion when positioning labels explicitly, several alternatives are available. For example:
Constructed points (refer to
Point and Line Construction for further information) may also be used for Label positioning operations. Refer to
Summary of Commands for further information.
