DRAW Reference Manual
Dimensioning : Summary of Commands : Miscellaneous Operations on Dimensions . . .
sets dimension type to Parallel
sets dimension type to Chained
DMSP value
for Parallel Dimensions, sets separation spacing explicitly
- for Parallel Dimensions, sets separation spacing using cursor
for Parallel Dimensions truncates dimension lines by a percentage specified
for Parallel Dimensions truncates dimension lines to a specified value in mm
DTER option
set dimension line terminator. Options: ARR, OBL, DOT, OFF
FTER option
set first dimension line terminator. Options: ARR, OBL, DOT, OFF, DEFAULT
set terminator size to 4mm (default 3mm)
OSHT value
sets projection line overshoot explicitly
sets projection line overshoot using cursor
projection line overshoot defined by a constructed point
PLCL value
sets projection line clearance explicitly
sets projection line clearance using cursor
- draw projection lines only
draw dimension lines only
draw projection and dimension lines (default)
